I was told by someone that this program could be used to save out MP3s. I have looked everywhere trying to figure it out, and I would like some info. Can you save MP3s of what you work on, or no? If so, how?
Posted Thu 19 Mar 09 @ 6:42 pm
you can record the set as you play it, it can be saved to mp3 or wav, there is a tab for recording, i guess it depends on which skin you are using as to where the tab is located. open that tab and press the record button, when your done stop recording. there is also a field to select the directory that the new file (mp3) is saved to.
Posted Fri 20 Mar 09 @ 9:48 am
