All,
I have been using a 32bit computer and my Hercules MK2 was working fine. Now that I have a new laptop using a Vista 64bit my Hercules MK2 doesn't work. I have downloaded the update for Hercules MK2 using Vista, update the new drive and I downloaded the DirectX9 however, I am still getting an error message(DirectX sound card problem). If someone can offer me some advice as to how I could get my system to work I would appreciate it.
Thanks!
Best Regards
Constatine
Thanks!
Best Regards
Constatine
Posted Thu 19 Mar 09 @ 8:01 am
seems like you need to go back into sound setup and re do your settings...
Posted Thu 19 Mar 09 @ 5:57 pm
you got to get 64bit drivers
Posted Sat 21 Mar 09 @ 11:11 pm
edit
Posted Sun 22 Mar 09 @ 3:53 am
