what are the VDJ commands for the arrows that divide the loops on VDJ, i cant seem to map that particular function to my DDM4000 at all. Does anybody know what the general midi command for those arrows are??
Posted Sun 15 Mar 09 @ 5:42 pm
nobody knows the functions??
Posted Wed 18 Mar 09 @ 3:24 pm
Does this command exist in vdj other than within skins? When i used the pro trial i couldn't find the command for it anywhere, either as a keyboard shortcut or as a mapable button to my RMX using DJcel's RMX config. I found the lack of its existence (or my inability to find it) pretty frustrating as I wanted to use just 3 buttons to control loops (8 beat loop, loop divide, loop double), rather than needing an individual button for each loop length i want to use (1/4, 1/2, 1, 2, 4 etc). Can anyone help?
Posted Sat 28 Mar 09 @ 3:18 am
Can't you use:
loop -1
and
loop +1
That halves/doubles the loop length IIRC. In fact, I think thats what is used in the default skins.
loop -1
and
loop +1
Posted Sat 28 Mar 09 @ 4:52 am
