Please please please can someone sort out the search on this site. It's no where near as good as it used to be. anyway rant over!
I'm trying to get visualisations working, Sonique specifically, but cannot seem to get anything at all. I've downloaded the latest pack of svp files, but despite searching like a bugger for the best part of two hours, can find any instructions that tell you where to put these files. So I've had them in their own sonique folder under the main vdj folder, in their own folder under the plugins\Videoeffect folder and then finally I just dumped all the svp files in the VideoEffect folder. No working visualisations in any configuration.
Hardware setup is I'm activating the visualisations on an external monitor using hardware acceleration directly to the card (not in window although I've tried that too), If I check and uncheck the "hide logo" the logo appears and disappears, if I use the negative plugin the external screen goes white. So I figure they must be working at some level, but sonque does not.
Found threads saying to update the DX versions, followed the link and done that.
Found another few threads relating visuals not responding when using certain usb soundcards, so I've tried all my soundcard configs as well, no joy.
So if anyone could enlighten me as to what I'm doing wrong I'd much appreciate it.
Ta
Ta
Posted Fri 13 Mar 09 @ 8:27 pm
go into config > choose video tab > go down to the bottom right drop down window and select sonique, to the left make sure you tick the box, come out of config and select effects > select video tab > select sonique > select/click on activate > select open > this is where you go to where you have your sonique folder, now open the folder and double click on a file, this will now run your sonique effects. you can now play with the two sliders for the type of effect you want. slide show delay will give you how long each effect will run for and the transparency will let you fade the soniques over other effects like a video, show logo etc...
if you have the time go through your individual soniques and delete the crappy ones, saves getting them up on the screen, if you get stuck i could make a video for you as looking at that i find is a lot easier than my explanations..... lol
Posted Fri 13 Mar 09 @ 10:14 pm
Thanks Tayla
That's exactly the instructions I couldn't find! All makes sense when you know how.
As a wise meerkat once said, "simples".
Denzel
Actually might by worth adding this snippet of info to the wiki?
Denzel
Posted Sat 14 Mar 09 @ 8:05 am
no probs denzel,i'm from meerkat manor peeps... don't worry mate we've all been there, still am.... lol
actually i'm building up a bank of simple video tutorials (for people like me, lol) and i'll think the soniques one will go in just nicely, just got to make the damn thing now...
don't forget to use the wiki if you can't find an answer on the forums, some good stuff there as well as the odd video tutorial.
Posted Sat 14 Mar 09 @ 8:30 am
Quote :
actually i'm building up a bank of simple video tutorials (for people like me)
Tayla, could you do one on "putting the seat down 101". Wait, forget the video. Just a drawing with simple stick figures would be fine.
Posted Sat 14 Mar 09 @ 11:35 am
would have thought you would know how to do that by now renee... you still doing your party tricks, lol
Posted Sat 14 Mar 09 @ 11:50 am
Thx for these really clear explanation!!!!!!!
I really appreciate THX
Posted Wed 01 Apr 09 @ 11:03 am
thank you, glad it helped...
Posted Wed 01 Apr 09 @ 11:09 am
finally got round to do that video for people still not sure, after you have watched this one i will bring out another to explain that... lol
Posted Sat 11 Apr 09 @ 8:50 am
"Tayla, could you do one on "putting the seat down 101". " i once starred in a "holding it in , in the elevator " video .......
'course , when i finally let it go , Buford just had to pick that moment to flick his bic ........
thought it was important for all to know that especially Renee
Posted Sat 11 Apr 09 @ 12:40 pm
