I'm aware of the licenses and such, so I was wondering if anyone would be so kind as to doing one for me? Just want vocals removed in one song. That's all. Somewhat of a newbish question but I'm a bit desperate. If anyone can help, it'd be greatly appreciated.
Thank you.
Thank you.
Posted Wed 11 Mar 09 @ 6:13 pm
Try this
Posted Wed 11 Mar 09 @ 6:33 pm
See, here's the thing. There's no instrumental for this song. It's just a straight rock song with vocals. I just want them removed. I don't care if the quality worsens a bit, but as long as the vocals are gone.
Thank you, though.
Thank you, though.
Posted Wed 11 Mar 09 @ 6:43 pm
Download Audactiy and try this..
http://audacity.sourceforge.net/help/faq?s=editing&i=remove-vocals
I think it works better if you have the CD and rip to WAV no compression then try to edit. Sometimes it works, sometimes not, depending on how the recording is also.
If that doesnt work theres more info here...
http://www.audacityteam.org/wiki/index.php?title=Vocal_Removal
Posted Wed 11 Mar 09 @ 9:50 pm
It didn't work. Damn. Any help, please?
Posted Sat 14 Mar 09 @ 3:59 am
As far as I know If the vocals overlap the sound theres not much you can do about it except for the process I've just mentioned. Perhaps doing a google search for the rock song and using keywords such as Instrumental or "vocals removed" or karaoke. You might find a good karaoke version out there.
Posted Sun 15 Mar 09 @ 9:53 pm
if you gave out the song your after it may help
Posted Mon 16 Mar 09 @ 7:53 am
