whats up guyz,
i used to dj with the hercules rmx but now i wanna get into turntables and so i need some help setting up my equipment.
i just wanted to know how do you set up the turntable weights and the antiskates.
i mostly beat mix hip hop music but would like to start scratching into my mixes, not extensively though,
this is what i use for my equipment:
virtual dj pro 5.2.1
numark ttx tts
numark cc1 cartridges
numark ppd01 for a mixer
hercules rmx for a soundcard
ssl2 tcvs
ANY ADVICE AND SUGGESTIONS ARE WELCOME AND HIGHLY APPRECIATED! THANKS GUYZ!
numark ttx tts
ssl2 tcvs
Posted Mon 09 Mar 09 @ 9:02 am
btw, my tts have a s tonearm...
Posted Mon 09 Mar 09 @ 9:43 am
You posted the same topic in three different threads.
Once is enough.
Once is enough.
Posted Mon 09 Mar 09 @ 4:49 pm
sorry, I am just anxious for answers, won't happen again
Posted Mon 09 Mar 09 @ 5:19 pm
anybody guyz?
Posted Wed 11 Mar 09 @ 1:30 pm
Google is your best friend!!!
Too long to copy paste, sorry brows it yourself.
http://www.turntabletech.com/tonearm.htm
Hope you will find your answer there...
Posted Thu 12 Mar 09 @ 2:09 am
haha thanks man...
Posted Thu 12 Mar 09 @ 9:06 am
Did you buy your tables yet ?..... I recently bought another pair on Craigslist.com and saved a huge amount of money. I got 2 technics 1200 m3d's with a vestax Pcv 003 mixer and two Ortofon Cartridges with 4 neddles all in Mint condition for 420 bucks. Carzy deal... Look in this website and you can find deals..
Posted Thu 12 Mar 09 @ 6:00 pm
yeah man,
i got 2 numark ttx tts, numark ppd01 digital mixer, the hercules rmx all for a insane deal, chec out the pics of my set up so far:
my dj setup pics: http://viewmorepics.myspace.com/index.cfm?fuseaction=user.viewPicture&friendID=21899956&albumId=3247149
Posted Thu 12 Mar 09 @ 6:01 pm
farhanashraf wrote :
yeah man,
Nice setup mate!
Posted Thu 12 Mar 09 @ 8:51 pm
thanks buddy! I really appreciate it! ;-D
Posted Thu 12 Mar 09 @ 8:57 pm
Adjust the counter-weight so that it's very loose and just about enough to keep the arm on the vinyl. The vinyl should be one sided with the non audio side up, if you don't have one, put the needle at the end of the vinyl just before the center sticker, i.e. the run off point. When you start the table you want the arm to stay on the record but not to follow into the center like usual, it should stay still. This is 0g of weight, so set your indicator appropriately. Then depending on your cartridge/stylus you want to put between 2.5g and 3.5g on the counter-weight by twisting it counter-clockwise. If you're using a straight tonearm you don't need to adjust the anti-skate, otherwise adjust it accordingly to whether you are getting skips or not when manipulating the vinyl (although it could be you're being too heavy handed). You could set a small amount on the anti-skate adjuster but you won't need much.
Also please register your pro serial number under your profile, you may find people more willing to help with questions like these.
Posted Fri 13 Mar 09 @ 8:33 am
oh k will do, i kep being lazy,
thanks for the info i really appreciate it..
Posted Fri 13 Mar 09 @ 11:52 am
