when i am using the timecoded vinyl and i slide the up faders down or the crossfader over the tune/sample stops playing so if i'm doin a scratch it stops when i cut it out if you get what i mean, anyone know how to sort it?
cheers
cheers
Posted Mon 09 Mar 09 @ 8:20 am
not sure....all I can suggest is check in your settings and see if you have fader start enabled....that used to mess me about a little.
Posted Mon 09 Mar 09 @ 9:14 am
checked in the config mate an cant even see an option for fader start.
heres me config
http://img3.imageshack.us/img3/671/virtualdjconfig.jpg
heres me config
Posted Mon 09 Mar 09 @ 9:50 am
Do you know I can't find it now either.
you want your crossfader on full if you are scratching.
what exactly is your set up?
Posted Mon 09 Mar 09 @ 12:26 pm
Do you have a fader start switch on your mixer?
Posted Mon 09 Mar 09 @ 12:31 pm
No fader start on the mixer
I got a djx 700 an 2 x stanton t62, cant get both decks workin at the same time eitha now
Posted Mon 09 Mar 09 @ 12:52 pm
im tryin to download the vocoder but it keeps telling me that my liscence doesnt allow me to download it. HELP ME PLZ!!!!!!!!!!!!!!!!!!!!!1
Posted Mon 09 Mar 09 @ 4:48 pm
Plugins and skins are reserved for licensed users only. To download these cool additions to VDJ please either, register your product or, purchase Virtual DJ from this site. Thank You
Posted Mon 09 Mar 09 @ 5:04 pm
Stop hi-jackin me thread
Posted Tue 10 Mar 09 @ 2:37 pm
