my total control scratch function does not stay lit,if i am moving the jog wheels or any other functions it stays in scratch mode but once i stop it dosent stay on scratch but goes back to regular functions,does anyone know a way to change this so it stays in scratch mode untill i exit by pressing the button again?
Posted Sun 08 Mar 09 @ 1:40 pm
Are you using the Traktor overlay?
Posted Sun 08 Mar 09 @ 4:56 pm
no i believe im using the cue plate
Posted Sun 08 Mar 09 @ 7:05 pm
Are you using the VDJ TC native remote or the plugin (moramax)?
Posted Mon 09 Mar 09 @ 2:30 am
im really not sure ,how can i telll what my setup is?
Posted Mon 09 Mar 09 @ 6:48 am
Do you remember downloading the mapper? Look in the external control folder in Documents / Virtual DJ / Plugins
Posted Mon 09 Mar 09 @ 4:05 pm
yes i downloaded the mapper and it is currently running
Posted Mon 09 Mar 09 @ 5:07 pm
Using the Plugin mapper might be the cause of this issue. In your own point of view, do you like this mapper? Otherwise you can delete the kco dll file on the external device plugin section then use the VDJ native instead.
Posted Tue 10 Mar 09 @ 2:37 am
i deleted the mapper from my pc but it still shows up in the external devices section, how can i remove it from there? i apologize for the simplicity of these questions but these are things i really have no clue about, when i delete effects from the save point they are no longer available but not sure how to do this for the mapper
Posted Wed 11 Mar 09 @ 9:55 pm
this is a new post in this topic but a slightly different problem but i didnt wanna flood the forum with questions about the total control,ive been using VDJ for about a year and until a few weeks ago i was using a hercules control mp3 with very few problems but with the total control its a little different,i was still looking for info about deleting the mapper but the new problem i have is that when i am mixing i record the mix every time but every time i record or even just mix for a while vdj keeps shutting down,sometimes i get the smiley face and red X message,but tonight i had a different message it was somethink about C++ (apologies,i shut it before realizing i might need to know exactally what it said),if someone who is familiar with vdj and the total control could help me it would be much appreciated,if possible i would like to correspond directly with someone off of the forums, but if not the forum is fine,my email address is on my profile( once again apologies,i dont wanna post and email on the forum)so like i said any help will be greatly appreciated
Posted Sun 15 Mar 09 @ 12:47 am
If your VDJ shuts down when recording this would not be related to the TC.
Do you have a crash log?
Posted Sun 15 Mar 09 @ 11:54 am
im not sure but i really dont think i do,im quite computer illiterate and am not sure exactly what the crash log is
i also remembered another problem im having and thats when i am mixing one song and setting up the other to a point when i use the jog wheel i get lots of static in the track thats playing but thats for another day,im just trying to get my setup to work as well as it did with hercules dj control mp3
like i said help is much appreciated and ill take any i can get
Posted Sun 15 Mar 09 @ 1:08 pm
Crash guard text is usualy saved in documuments > Virtual DJ.
You should make a ticket with the details from this file an an explination of the issue.
Posted Mon 16 Mar 09 @ 4:37 am
good call
thanks
thanks
Posted Mon 16 Mar 09 @ 11:27 am
