Hi guys hows it going. I hope good
So i just wanted to know someting cuz i got numark total control for over a year already and also that midi control came with the software
numark cue.
The question is: is there anyway to upgrade it to virtual dj pro.
Cuz it only says upgrade to numark cue pro but idk so if u guys know something let me know please =)
numark cue.
Posted Wed 04 Mar 09 @ 6:27 pm
yea on this website go to the tab above where it says buy...you will get a discount :D!!!!!
Posted Wed 04 Mar 09 @ 10:00 pm
AWESOME. lol i didnt know that and now i see that since i got total control i get a discount.
Its actually pretty cool.
Soon im gonna be a pro user.
Thanks =)
Thanks =)
Posted Thu 05 Mar 09 @ 12:05 pm
Thanks =)
Thanks =)
You can also get a discount on cue direct from Numark:
US support[at]numark[dot]com
UK uksupport[at]numark[dot]com
Posted Thu 05 Mar 09 @ 2:45 pm
skyfxl i sent you a pm? you don't respond when it has to due with the products you provide?
Posted Fri 06 Mar 09 @ 2:37 am
You can upgrade to VDJ PRO with a discount at bottom of this page :
https://virtualdj.com/buy/
Posted Fri 06 Mar 09 @ 7:28 am
Sorry Its just not possible to check this every day.
I have responded to your PM
Kind Regards.
S
Posted Sun 08 Mar 09 @ 12:07 pm
Hey guys!!! anyone knows if you can use the hercules RMX kit with numark virtual vinyl (i guess the CUE software & the coded VINYL. YEAH I guess the answer is yes..but any complications? Puttin my first kit plans together...thanks
Posted Fri 29 May 09 @ 4:32 am
Yes you can use your RMX with Numark Cue/VV
Posted Fri 29 May 09 @ 4:34 am
