Hi I am interested in purchase the Virtual Vinyl and wanted to know what kind on cd player would I need? Basically do I need a cd turntable or just any cd player/mixer. Thanks in advance for your help
Posted Sun 01 Mar 09 @ 6:29 pm
you can use any audio mixer, cd-player or turntable with virtal dj/virtual vinyl/cue.
Posted Sun 01 Mar 09 @ 11:53 pm
Are there any suggestions on a cd-player that's under $350...and is ok for a club dj.
Posted Mon 02 Mar 09 @ 10:38 am
really any numark, denon, pioneer, etc
just about all are reliable...
what are you looking for?
Posted Mon 02 Mar 09 @ 11:00 am
and check musiciansfriend.com for what they have
I have been looking at the cdj-200, but I'll need 2, plus a mixer and I'm on an $800 budget for the setup.
Posted Mon 02 Mar 09 @ 11:25 am
also will these work and do u think these are worth the money....GEMINI DJ CDJ202...http://www.idjnow.com/StoreModules/ProductDetails.aspx/PID=CDJ202
Posted Mon 02 Mar 09 @ 11:31 am
I would advise you look at an alternative brand as these have a very low output.
Posted Mon 02 Mar 09 @ 11:43 am
Before you buy anything. Save up alittle more and get something good. If you buy something on a budget, you will not like it after a month or so and would want to sell. No one would wanna buy it from you...
Posted Mon 02 Mar 09 @ 2:06 pm
Thanks you guys,the advice is helping me narrow down my options...now I've been browsing and looking around...I've ran into 2 more devices that I'm curious on: the CORTEX HDTT-5000 or the Numark CDX Direct-Drive CD Turntable .....again thanks and keep the help/advice coming.
Posted Tue 03 Mar 09 @ 4:57 am
