i have tried out the trial and before purchasing would liek to know some things about the software to hardware compatibility.
recently i was looking at a product on samash.com
http://www.samash.com/webapp/wcs/stores/servlet/product_Battle%20Pak%204%20DJ%20Turntable%20Package_-1_10052_10002_-49966007_cmCategorySA182609
which is a numark turntable and mixer package for around $400 which is a reasonable price for me.
would i be able to use timecoded vinyls with these turntables?
would i be able to hook this up to my pc as well and if so would i need a seperate soundcard?
what i really need to basically know is if i buy this would i be able to use it with virtual dj on my pc
thanks
and any help is appreciated
thanks
Posted Sat 28 Feb 09 @ 10:19 pm
1st question, Yes they will be fine.
2nd question, You will need a 4in/4out soundcard, something like a Maya44, which is easy card to use and a good starter and a fairly inexpensive card too.
TT's go to the 4 inputs of the card, the 4 outputs go out to the mixer.
Posted Sun 01 Mar 09 @ 6:28 am
thank you, exactly the info i was looking for
Posted Sun 01 Mar 09 @ 11:46 am
