i currently have vdj 3.2 and i no there are upgraded vrs of vdj like 5.4 but i do not no if i should upgrade
right now vdj runs ok, if posable by upgradeing to vdj 5.4 will this fix my problems
1} when scratching a song it sound very computery. thats the best wat i can describe it "not like a regular scratch"
2} also there is some lag when I am pulling songs off of my exturnal hard drive to play. "will upgradeing fix this"
heres my set up
dell d800
2 dns 3500
newmark dmx 06
and the asio 4 in and 4 out
also please respond to this post, do not just look at this post and offer any positive feed back
heres my set up
dell d800
2 dns 3500
newmark dmx 06
Posted Sat 28 Feb 09 @ 7:41 pm
You can install the new version, and still keep the old one. That way if you are not happy, you can simply switch back. Just a thought.....
Posted Sat 28 Feb 09 @ 7:46 pm
o cool but do you think that it will fix my problems .. and or whats costing my problems
Posted Sat 28 Feb 09 @ 7:54 pm
No, I am not sure what is causing your problem. I bet someone chimes in with a suggestion or two for you though ;-)
Posted Sat 28 Feb 09 @ 9:41 pm
not a fix for your current version, but when you go to install new virtualDJ, when the installer asks where you would like to install, change the directory to someting like \virtualdj5
this will let you have both new and old on your system.
Posted Sun 01 Mar 09 @ 12:49 am
There have been many improvements to the sound engine since 3.2 mostly focusing around the DVS (timecode and scratch) features.
Posted Sun 01 Mar 09 @ 8:30 am
As sort of a testimonial, I must say that the newer versions (5+) are better performers than the older ones, especially where it concerns latency and sound issues while using external devices, in my experience, at least...Hope this helps in your decision ;)
Posted Sun 01 Mar 09 @ 2:43 pm
No need to do that ... just rename your current virtualdj.exe file to virtualdj_3.exe ... then install VDJ 5 ... you will be fine. But your database will not be ported to the new version. Your VirtualDJ v5 database will have to grow from scratch.
The improved speed of pulling tracks off your hard drive .. no not necessarily because that is a drive access time/performance issue and VDJ 5 won't necessarily improve that.
As for the computer sound .. yes the sound engine has been improved from version 3 to version 5.
Posted Sun 01 Mar 09 @ 4:37 pm
version 5.4.... hmmmmm
pretty sure it is not that far
basically i think it only goes up to 5.2.1 for now
and yes.. 5.x does correct a h a lot of issues you may be having in 3.2
better quality too
better quality too
Posted Sun 01 Mar 09 @ 5:10 pm
