looking forward to it, you no me I'm always up for a suggestion lol !!
Posted Mon 16 Mar 09 @ 9:43 am
https://virtualdj.com/addons/7252/Scratch_Control.html
come and get it !!!!! the .exe was renamed wrong before but now its fine.
the split/single waves are the 1 & 2 located at the right side of the rhythm wave display.
if you have no waves press the 1&2 , its just for now.. i'll fix this later
Posted Mon 16 Mar 09 @ 6:18 pm
I like It
Posted Tue 17 Mar 09 @ 9:53 am
L2
absolutely great skin again !!
really like the colours they look great together and also how you\'ve moved the small cbg block window to just under the wave form display
it would be great to just have a cpu meter and maybe to show what pitch% your using somewhere
apart from that everything else is great
when assigning beatlock in general midi the sync button on the skin does not light up though ! so cant tell if its engaged or not
here's for the big suggestion though lol !!
what would be the chances of adding a second panel here
and adding the rmx 6+6 and the steel 12+12 effects bank window to it
or maybe doing a skin variation of it later on
as i said great looking skin really like the layout of it and as always thanks for the time you put into them
cheers aubs
cheers aubs
Posted Tue 17 Mar 09 @ 5:32 pm
Cool.. glad you like it. The chance of anything changing is very high at this point. I want to see what people like and dislike. This is a good solid foundation and the rest will only get better..... that is with the help of my skin fans!
Posted Tue 17 Mar 09 @ 5:38 pm
LOL... I didnt think the font i used was as BIG as in other skins so i was not sure if it would be ok or not.
I'll try and fix it up soon. Thanks for pointing it out.
Posted Wed 18 Mar 09 @ 8:19 am
I like it very much, clean and clear. It would be very nice with a cross fader. Would you consider adding it..?
Posted Wed 18 Mar 09 @ 9:02 am
like the skin ! thx, great workin with it, but one thing would be nice 2 see if the kill switches are active (workin with rmx console and they dont glow).....
Posted Thu 19 Mar 09 @ 1:38 am
I just downloaded this skin looks good and works good even without the cossfader since i got external controlers
Keep it up listen2 and by the way is that u wearing the mask? on ur avatar lol
Posted Fri 20 Mar 09 @ 11:36 am
sorry haven't got back to you L2
that would be great if you could add the 12+12 effects bank to the skin
would really love to ditch the eks xp5's and just use the dj control steel
thanks for considering it
aubs
aubs
Posted Sat 21 Mar 09 @ 8:34 am
Good job bro l love your now skin
Posted Sun 22 Mar 09 @ 5:43 pm
dude i can turn it off and on thats sick :)
can u add to where u can turn off and on the the leave meter
i don't use it
very nice skin it seems to work very well for me
it would be nice to have 4 cue points on there :)
i don't use it
Posted Sun 22 Mar 09 @ 8:52 pm
thanks
Posted Thu 07 May 09 @ 4:31 pm
I was thinking about updating this skin soon. What would people like to see?
I am going to improve the graphics but would this skin benefit from verticle scratch waves or should i keep it pretty much as it is add scratch waves horizontal??
Posted Thu 04 Jun 09 @ 8:17 am
