Hello I have used mixmeister to scan for bpms as it automaticly adds it to the mp3 tags. I then load virtual dj and play it and virtual dj automaticly changes the bpm. I was wondering if I can disable bpm's in virtual dj so it will keep the bpms of my mp3s that mixmeaister finds. Also is mixmeister the best for bpm detection program? From what I have gatherd on the net it is one of the best for detecting bpms. However sum of my slow r&b soul songs are like 120 bpms when they are actually only 72 bpms. Is there anyway to fix that. Basicly I want all the true bpms of my songs on virtual dj as Im a dj mixer and load songs like every minuete for my mix. I cant tap bpms for all my songs because I flip threw hundreds on a set and have thousands of mp3s any help would be greatly appreciated.
Logic
Logic
Posted Fri 27 Feb 09 @ 1:00 pm
I gave you an answer in the PC Tech forum --- Do not make multiple posts in multiple forums.
https://virtualdj.com/forums/105523/PC_Version_Technical_Support/Please_help_needed_bpm_detection.html
Posted Fri 27 Feb 09 @ 1:04 pm
