Having massive troubles trying to get VV to work, is driving me up the wall.
I have everything wired up correctly, from my turntables to my mixer and to the soundcard. Problem is, whenever I choose Timecodes as my input, they show the track running and respond accordingly, however no sound comes through my mixer. If I have sound setup as a 3 lines mixer and VV soundcard WITHOUT the turntables, the tracks will play normally without any problems what-so-ever, sound and all.
Checked my needles etc, no problems there as they play normal vinyl without a problem. Just odd that no sound registers when I have timecodes set as my input.
Im updated to version 5.2.1 Pro which I think is the most recent. Any help would be great!
Posted Fri 20 Feb 09 @ 12:16 am
check your OUTPUT settings.
What you use as input (timecode) should have no affect on your outputs.
Posted Fri 20 Feb 09 @ 12:21 am
Justice.Fresh
Professional edition user
Im having the same problem. Only when i try ti auto config my TCV it registers an error saying that my cables are not connected or the sound on my souncard is wrong.
Firstly i know my cables are ok and secondly i dont know of any way to adjust the sound on the soundcard.
I have set mine up for external mixer (i have tried 3 line mixer too but same shit)
Also my software opens as cd decks...... I dont know how to change that.
I have no broadband at home yet so i had to download thew new software (5.2.1) at work. I still have to get home and upload it yet, will this help??
Posted Fri 20 Feb 09 @ 6:12 am
Unlikely as I am also using 5.2.1 and am getting no results. Still stuck
Posted Fri 20 Feb 09 @ 4:58 pm
things seem to have taken a little turn for the better. i uploaded the new software and i went to auto config my TCV it no longer says that no tcv is not playing. but now it wont auto config. once i press auto config the qualty just switches back to silent. its getting really frustrating now. when i change my sound settings and pess play on my software i can hear my music playing through my mixer (im currently in between speakers so im listening on my headphones). And thats another thing, I shouldnt have to press play on my my software to get the music to play. I should just have to play the vinyl and shouldnt it just play?? I cant get the software to change from cd decks to turntables
Posted Sun 22 Feb 09 @ 5:42 am
What should the output settings be?? Just numark soundcard?
Posted Sun 22 Feb 09 @ 5:44 am
Got it. I stupidly hadnt got the tcv's playing at the right time so of course it wouldnt auto config would it. In the immortal words of Homer Simpson WWOOOOOOOOOOOHHOOOOOOOOOOO.
HAPPY OUT :)
HAPPY OUT :)
Posted Sun 22 Feb 09 @ 6:19 am
