i have a gateway ml6721 laptop and i plan on buying a hercules rmx....does anyone know if the notebook will work or do i need to save for a more powerful notebook....cause i dont wanna drop close to 4 bills if it aint gonna work.... i even copied and pasted the specs, to my laptop on this thread (see below...)....any SERIOUS answers would be awesome....thanx alot guys...
ML6721 Notebook Specifications
Part Number: 1014764RGateway ML6721 Notebook
Feature Description
Processor Intel® Dual-Core Mobile Processor T2310
1.46 GHz | 1 MB L2 cache | 533 MHz FSB
Chipset Intel® GL960
Display panel 15.4-inch WXGA (1280 × 800)
Memory 1024 MB 667 MHz DDR2 SDRAM (2 × 512)
Operates at 533 MHz
Total slots: 2 DDR2 slots | Available slots: 0 DDR2 slots
Video controller Intel® Graphics Media Accelerator X3100
Up to 384 MB of Dynamic Video Memory
Audio High definition audio - 2 channel
Hard drive 160 GB 5400 RPM SATA hard drive
Optical drive 8x Multiformat Dual Layer DVDRW with DVD-RAM with Labelflash™
Write maximum: 8X DVD±R, 6X DVD-RW, 8X DVD+RW, 2X DVD-R DL, 2.4X DVD+R DL, 5X DVD-RAM, 24X CD-R and 16X CD-RW discs
Read maximum: 8X DVD-R/RW/ROM, 4X DVD±R DL, 5X DVD-RAM, 24X CD-R/RW/ROM discs
Modem Integrated V.92 56K modem
Network 10/100 Ethernet LAN
802.11a/b/g wireless LAN
Memory card reader 5-in-1
Memory Stick®
Memory Stick Pro®
Multimedia Card™
Secure Digital™
XD
MiniSD and RS-MMC (when used with adapter that is supplied with card)
Interfaces Four - USB 2.0 ports
One - VGA port
Microphone jack
Headphone jack
RJ-45 port
RJ-11 port
One - Kensington lock slot
Power input
Pointing device Touchpad with vertical scroll zone
Expansion slot Expresscard™ Type 54
Battery 6-cell Lithium-ion
Dimensions 1.31 to 1.40-inches (H) × 14.09-inches (W) × 10.39-inches (D)
33 to 36 mm (H) × 330 mm (W) × 264 mm (D)
Weight 6.24 pounds
Feature Description
Operates at 533 MHz
Memory Stick®
Memory Stick Pro®
Multimedia Card™
Secure Digital™
XD
One - VGA port
Microphone jack
Headphone jack
RJ-45 port
RJ-11 port
Power input
Weight 6.24 pounds
Posted Wed 18 Feb 09 @ 6:06 pm
I'm running virtualDJ flawless with an hercules RMX on a DELL d400 1.6 ghz, 512mb RAM. (I really like to brag about how crappy my laptop is!)
Just turn off the wifi and all unused processes and you should be good to go.
Posted Wed 18 Feb 09 @ 7:32 pm
hehe, just makes you feel so good....
Posted Thu 19 Feb 09 @ 1:28 am
yeah cuz like I askeed tech support the same question and they said I should have at least a gig of ram...I was like WTF?...but if you say so maybe I ll give it a shot....thanx alot
Posted Thu 19 Feb 09 @ 12:11 pm
I ran it on on a 1.79 GHz 512 of RAM Compaq laptop that is 3 years old. It worked just fine. Now I run it on a 2.0GHz 1GB of RAM desktop that is 8 years old and it works the same. So dont worry you should be fine.
Posted Fri 20 Feb 09 @ 1:21 am
