Hi,
I am trying to switch between different effects with the fx buttons. The middle button on the hercules control activates the fx and the other two move up and down the different effects.
The problem is I can only move up and down through a few effects with the fx buttons, seems to be stuck on a few different fxs. If I want to activate other fxs I have to do it via the laptop mouse buttons.
Any ideas ?
Any ideas ?
Posted Sun 15 Feb 09 @ 8:59 am
With the MK2 DJC edition there should be a button to select between FX, Cue and Loop. Then you can use FX1, FX2 or FX3 that you have previously selected in the effects menu.
In the RMX djc edition, someone made a new skin that lets you remap the 6 buttons. Very handy.
Posted Mon 16 Feb 09 @ 10:40 am
Hi marculos, seem u are using the pro version.
Pls register ur pro version in ur profile then u can download the mapper to change the behavior of the console.
The pro version is different compared to the djc version.
Regards;)
Regards;)
Posted Mon 16 Feb 09 @ 10:48 am
