Hi to everybody.
I've just bought a Dj Tech I-Mix Reload midi controller. It comes with Traktor and Deckadance, but i'd like to try it with Virtual Dj. The is there's no native configuration in it, so, does somebody know if there's any configuration out there?
Thanks!
DjDasvid.
Thanks!
DjDasvid.
Posted Tue 10 Feb 09 @ 6:09 pm
You could use it with VirtualDJ, it is a midi controller.
You would be able to use the General midi option in the remote control tab, and map it yourself. It is quite easy to do and doesn't take that long to pick up.
Posted Tue 10 Feb 09 @ 6:46 pm
SSupp DjDasvid!
u got it workin man? i just got this new Dj Midi Controller, Dj-Tech I-Mix wondering how can i play the mixer with vdj.. cant figure out where the remote tab is.. cud u help us out mate.. cheers.. u r a champ!
Posted Sat 16 May 09 @ 8:51 am
You need to look at
Config>Remote Control>General Midi.
Posted Sat 16 May 09 @ 8:55 am
