Topic: I NEED SOME ADVICE AND GUIDANCE
hello
i have virtual dj and recnetly brought sum vinyl decks
i now whant to go to the next level and wire them to the virtual dj
do i need an asio soundcard or will other makes fit the bill
also do i have to buy timecoded vinyls off virtual dj or will any time coded vinyls do as i need them soon
and lastly do i need any special needles or is it simply just the time coded vinyls
thanks everyone
Posted Mon 09 Feb 09 @ 7:48 pm
What i recommend:
1st: Get a full legal version of VDJ PRO, cracks and those other versions out there ARE VERY UNSTABLE, and you don't want an error to happen right in the middle of your set, your face will turn red and people WILL point and laugh at you!
2nd: Get something along the lines Hercules RMX (RMX comes with legal version of vdj), BCD3000, MAYA, Native Instruments sound card(not limited to these, search the forums, many options are available)
3rd: Search and read the forums, will take a while for you to get a flawless system up and running and doing some research will save you time and money, as not all hardware work the same way with every computer.
4th: I REPEAT: Get a full legal version of VDJ PRO, cracks and those other versions out there ARE VERY UNSTABLE, and you don't want an error to happen right in the middle of your set, your face will turn red and people WILL point and laugh at you! THIS HAPPENS ALL THE TIME TO THOSE WHO TAKE SHORT CUTS.
yes i fully intend to get the full legal version
with sound cards will a maya 44 work with the virtual dj and my vinyls
also a shop sells timecoded vinyls can i purchase them from their or do they have to be virtual dj ones
thanks alot m8
thanks alot m8
Yes the Maya44 will work, there's quite a few guys on here, that use it, I do for my TCV set up.
You can only buy VirtualDJ timecoded vinyl's from this site.
https://virtualdj.com/buy/
But also you can use Numark repalcement timecodes, you can get them (or order them) from any Numark agent.
