Hi all,
Temporarily switched to a VCI-300 and Itch, but came back to Virtual DJ and it's good to be home.
Now looking into getting a controller for Virtual DJ and liking the look of the Stanton SCS 3D. If you're using this, what do you think of it and how compatible is it with Virtual DJ? and decent mappings around?
Thanks a lot,
Russell
Thanks a lot,
Russell
Posted Tue 03 Feb 09 @ 6:50 pm
i would wait for the ns7
Posted Tue 03 Feb 09 @ 7:00 pm
Done some more research and seems the SCS 3D isn't too highly rated by users. Should I just go ahead and get the Hercules RMX? Seems like the obvious choice I've been avoiding all along...
Posted Wed 04 Feb 09 @ 11:54 am
blueski wrote :
Should I just go ahead and get the Hercules RMX? .
U have a VCI300 & you want to buy an Hercules RMX ?
What are you drinking ?
Posted Wed 04 Feb 09 @ 3:38 pm
ha
Posted Thu 05 Feb 09 @ 12:07 am
Love the VCI-300.. don't rate Itch too much. No effects, no proper beat matching, etc. It only beats Virtual DJ on the fluency of scratching, since it uses hi-res midi (which VDJ doesn't support).
I mostly play electro, so for me, Virtual DJ is the better option, at least until Itch catches up. Now I'm back, wondering which controller (if any) to go for.
Posted Thu 05 Feb 09 @ 8:21 am
If you want proper beat matching you must use your ears ...Itch Bpm engine is not the best .
Posted Sun 08 Feb 09 @ 2:59 pm
Need help!
Got two Stanton SCS.3d controllers that I would love to get to work with virtual DJ Ver 5 Pro. Any suggestions?
Posted Wed 23 Sep 09 @ 5:32 pm
blueski wrote :
Hi all,
Thanks a lot,
Russell
Thanks a lot,
Russell
mjh99ent
Experienced pro user
you might wanna holla at this dude
http://www.youtube.com/watch?v=czhzeOdwnqo
Posted Wed 23 Sep 09 @ 11:09 pm
