Hi All,
I was wondering if any of guys could give me a few pointers. I've tried to look at some of the sticky guides but I "don't have the necessary accreditations" yet.
I used to DJ many moons ago, playing house and trance off good old vinyl in clubs across Central Scotland.
I have most of my vinyl on mp3 now. I have been asked to come out of retirement for an old school night.
I would like a controller that I could manually adjust, just like vinyl. I would rather not go down the timecode vinyl route as I like the idea of being compact and portable (in case I have to make a quick getaway, lol!)
Should I get another soundcard? I just have a bog standard Dell laptop. I will be using virtual dj.
Many Thanks in advance.
Steve
Steve
Posted Mon 02 Feb 09 @ 1:47 pm
What do you mean by manually adjust?
And yes, you will most likely want to get a high-quality soundcard. Built in ones are usually not all that.
Posted Mon 02 Feb 09 @ 2:19 pm
any idea of the budget you want to spend if it's just a one off night...
Posted Mon 02 Feb 09 @ 2:30 pm
On the old technics I used to speed up and slow down the track by moving the plate with my fingers.
I'll consider any budget at the moment.
What soundcards would you recommed?
Thanks
Thanks
Posted Mon 02 Feb 09 @ 2:47 pm
