Does this give you access to the vdj plugins on this site ?
also - & sorry if this is a stupid question - does Cue 5 Pro do the DMX lights control ?
Posted Sat 31 Jan 09 @ 12:08 pm
and - does it play .zip karaoke files ?
basically what are the differences between Cue & VDJ ?
Posted Sat 31 Jan 09 @ 12:11 pm
packaging is the difference...
Posted Sat 31 Jan 09 @ 12:29 pm
what about the vdj plugins ?
Posted Sat 31 Jan 09 @ 12:40 pm
its the same program :) depends on where you buy it online its vdj at stores its cue
Posted Sat 31 Jan 09 @ 12:45 pm
go for pro if you are gonna update...
Posted Sat 31 Jan 09 @ 2:03 pm
Cue will give you all of the features, updates , skins and plug-ins.
It is distributed by Numark in DJ stores.
Posted Sat 31 Jan 09 @ 2:55 pm
