Hello everyone.
Im having asio problems
well first i use technics and time coded vinyls. I want to record but i can only record using WDM and not ASIO, but i need to record from ASIO as im using TCV which i cannot use with WDM.
When i click record it just says, "record error" "error in the asio driver" Why?
can someone please help me with this please as i want to actualy buy virtual dj and start recording mixes using tcv.
Posted Sat 31 Jan 09 @ 5:31 am
can someone help me please.. :)
thank you
thank you
Posted Mon 02 Feb 09 @ 11:51 am
You can not record in ASIO mode. This is documented in the manual that came with the Hercules controller.
You will need to use an external recording solution if you wish to record using ASIO.
Posted Mon 02 Feb 09 @ 12:01 pm
