whats up everyone,
Just picked up the Total Control and want to register it with virtual DJ but cannot find the serial number that looks like virtual dj's example... the one on the box shows (21) N and then a bunch of numbers... Anyone tell me where I can find the serial number?
Posted Tue 27 Jan 09 @ 6:49 pm
Use the serial number on the CD that came with the Total Control. That will give you the icon for this site..
Posted Tue 27 Jan 09 @ 7:01 pm
only 2 cd's came with the total control, traktor and cue
Posted Tue 27 Jan 09 @ 9:42 pm
Use the CUE serial number...
Posted Tue 27 Jan 09 @ 10:02 pm
Hey,
Well I Have The Total Computer DJ And I Cant Seem To Find The Serial. All That Came Was The Total Conrol, DJiO Interface And Traktor 3.
Please Help Locate The Serial.
Thanks, Daniel
Thanks, Daniel
Posted Tue 16 Jun 09 @ 12:28 am
TrenDMuzic wrote :
Hey,
Thanks, Daniel
Thanks, Daniel
Did you buy this brand new, or was it second hand.
If it was second hand and you didnt get VDJ in the box the i would assume that either it was missing from day one, or the previous owner has used it and activated it. If he has then unfortunately you will not be able to transfer the license to yourself. You will need to purchase a new one.
Hope that helps.
Posted Tue 16 Jun 09 @ 4:07 am
If you brought this new, numark are no longer shipping the total control with cue they are only shipping it with traktor now.
Posted Tue 16 Jun 09 @ 5:04 am
I Did Buy The Controller New. It Did Not Contain Numark Cue And/Or VDJ. Does Not Having That Mean That My Purchase Of Total Computer Wont Let Me Register Me Device?
Posted Tue 16 Jun 09 @ 10:40 am
@ all
The serial of the total control is on the cue cd, well no in the cd but in the case on the back.....
u will see something like ''powered by virtual dj'' and somewhere there is the serial
Its gonna be something like this: XXXX-XXXX-XXXXX
I hope this helps
DJ ALEX
I hope this helps
DJ ALEX
Posted Tue 16 Jun 09 @ 2:42 pm
If it was ponly supplied with traktor and not Cue. Then there is nothing to register on this site :(.
With previous versions of the TotalControl it was supplied with Numark Cue. This is what is registerd on the website - not the controller itself.
Hope that clears things up for you.
Posted Tue 16 Jun 09 @ 3:02 pm
I JUST BOUGHT THE TOTAL CONTROL BUT ITWAS SECOND HAND AND IT DIDNT HAVE THE SERIAL NUMBER WHAT CAN I DO IF ANYTHING
Posted Fri 28 Feb 14 @ 5:14 pm
Sadly, nothing. It's the software that gets registered, not the hardware.
Posted Fri 28 Feb 14 @ 6:54 pm
