Hi, was wondering if anyone could help me with any of the following
A) When doing an automix_skip or double clicking an item in the playlist, it uses something like a 4 second default crossfade. I thought this used the automix length setting which I have set to 0? I tried turning crossfader to disabled and auto cross length to 0 as well in preferences but it still always uses the 4 seconds. Is this a bug?
B) Is it possible to get VDJ to reanalyse the automix entrance/exit markers? After I have (accidentally) dragged a marker it remembers this new position and I want to get it to go back. I'm sure it happened once but I don't know how I did it. When experimenting I dragged one to the beginning and now can't get the track to play because it isn't on the screen long enough to correct it!
C) The pitch/tempo doesn't reset when going to a new item in the playlist. The option in preferences says reset pitch on load which is different I guess to using the automix so this might be a design decision but I'd have preferred the option.
Posted Mon 26 Jan 09 @ 6:40 am
Okay found out how to solve B a few minutes later. Reanalysing the BPM does the job.
Posted Mon 26 Jan 09 @ 6:44 am
