We are just getting started with Virtual DJ. I'm wondering what the best way is to take the sound out of the laptop into my board. It will be going into a channel on the board via quarter inch jack. Should I take the sound out of the computer from the headphone jack or through USB? Can it go directly into board? What should the sound setup be in VDJ?
Thanks in advance for your help!
Posted Fri 23 Jan 09 @ 6:17 pm
Ive run it both ways..i ran my laptop strait to a mixer from headphone out to the in on a mixer..just depend on your mixer and your settings on your lappy..as it may come out scratchy if not properly adjusted..havent tried the usb to the board..may have a better signal tho/
Posted Mon 26 Jan 09 @ 4:10 pm
I'VE GOT A NUMARK "DJIO" THAT RUNS USB OUT THEN TO EXTERNAL MIXER. GREAT PRODUCT, BETTER SOUND THAN GOING THROUGH HEADPHONE JACKS.
Posted Tue 03 Feb 09 @ 7:21 pm
if you run it from your headphone jack you will only get mono on each channel and will have to use a y splitter, best get an external sound card to run to your mixer for best results.
here's one way to set it up
basically if you cant follow the clip
go to config
soundsetup
outputs > external mixer
soundcards > mono seperated
output channels give you white lead/left channel red lead/right channel to your mixer
you will have to use a y splitter for each channel to get dual inputs into mixing desk
which of course will only give you mono sound output
@djstocker, please do not use caps while making a post.
Posted Tue 03 Feb 09 @ 7:51 pm
To satisfy Tayla\\\\\\\'s post, you need the following:
x1 pc.
x2 pcs.
x2 pcs.
x1 pc.
x2 pcs.
x2 pcs.
Posted Wed 04 Feb 09 @ 1:38 am
I have an hp laptop with two headphones outs , i need to be able to listen through my headphones to one song then play another over a PA system how can i do this? and what settings would i have to enter under configuration
Posted Wed 04 Feb 09 @ 9:24 pm
I have not been able to find a headphone that will attach to the female rca of that splitter you show tayla.yet?
Posted Sat 07 Feb 09 @ 2:08 am
GEO
The option you are asking is not possible, you can either play the master to your laptop speaker and the monitor to the headphone or vice versa. The fact is although you have 2 headphone jack onboard on your laptop but it's common to each other. Unless you'll use the mono split set-up.
Posted Sat 07 Feb 09 @ 7:34 pm
bryan, have you looked for an in line connector for the rca...
Posted Sat 07 Feb 09 @ 8:26 pm
I was wondering the same thing. I have been running headphone 3.5" into 2 yadapters into my mixer. I was looking at the Numark DJio, but would there be much of an advantage of the DJio?
Posted Sun 08 Feb 09 @ 9:30 pm
Hi,
like Dj Stocker 55 said it is best to run out of a 2 channel soundcard into a mixer,
i use a Gigaport into an external mixer , channel 1 left player , channel 2 right player,
then you can cue from the headphones plugged into the mixer. This way you can use
any analogue mixer.
any analogue mixer.
Posted Wed 11 Feb 09 @ 12:00 pm
