Got the RMX the other day.
No problems with it, a nice piece of kit, sounds find in a nightclub.
Only problem is, somethings there a pause/jump in the song. Its only small, but its not very profesional, and it reflects bad on the club.
Havent got a clue about the performance things on the config menu.
Just wondering if anyone has had the same problems or anyone know how to stop it doing this.
Cheers
Gareth
Cheers
Gareth
Posted Thu 15 Jan 09 @ 8:55 pm
take a look in the hardware forums there's a whole section on the rmx that will help you...
Posted Fri 16 Jan 09 @ 4:30 am
Hy pirate,
maybe this helps
config / performance
pusher absolut to the left
latency to auto
save mode & overclock disable (you must experience with this, bith or only one of them)
scratch for quality , simple algo
basic inter. enable
mastertempo up to fast
One possible thing!
Bye
Haui
PS You have nice sisters ;-)
maybe this helps
latency to auto
basic inter. enable
One possible thing!
Bye
Haui
Posted Fri 16 Jan 09 @ 4:51 am
