How to understand this option ?
Does it automaticaly selects the best gain level for you ? Cause you don't realy can see if you are playing int the red or yellow part on the UI .
Thanks,
Thanks,
Posted Tue 13 Jan 09 @ 9:23 am
Yes, in a nutshell that is what it does.
Posted Tue 13 Jan 09 @ 9:26 am
And if u use not the auto gain fucntion, how do you manage to set the correct gain level ?
Posted Tue 13 Jan 09 @ 9:55 am
by manually moving the gain slider or knob on the mixer. I have mine set to normalise to 0db. no problems.
Posted Tue 13 Jan 09 @ 9:59 am
