Hi
I seem to have prolem with the EQ in my version of VDJ (5.0.7)
I can use the EQ when plaing the music through the master, but at the same time i would of coursed like to adjust the EQ for the tune i'm about to mix and pre listen to it in the head phones, but i can't hear the sound chages in the head phone, only start to hear it when i crossfade,
Is there a setting to fix this? I can't remember having this problem with my last verion!
Posted Mon 12 Jan 09 @ 7:35 pm
This is possible, however the utility to enable EQ in headphones can only be downloaded by registered users.
Regards
Keith
Regards
Keith
Posted Tue 13 Jan 09 @ 6:42 am
I had the same problem. When I tryed mixing, my earphones wouldn't let me listen to my EQ modifications. But when I went to my friends house and used his earphones (they were more expensive), I would slightly hear my EQ modifications. For example, when I kill the bass, the bass would kill in the earphones.
Maybe it is our earphones..
Or, Kradkliffe was right.
One more thing. Maybe if you plug your earphones in your mixer, you would hear everything just fine. I'm just 14, and I'm struggling to get a Numark Mixer. lol
Maybe this helps!
See you!
[Unregistered User, Struggling To Buy Virtual DJ]
Maybe this helps!
See you!
Posted Tue 13 Jan 09 @ 7:12 pm
"This is possible, however the utility to enable EQ in headphones can only be downloaded by registered users."
really?
gay.
really?
gay.
Posted Mon 12 Jul 10 @ 3:36 am
