My sound is very muffled when I use my Virtual Vinyl. I think it may be the actual Virtual Vinyl box. But when I record there isn't anything wrong with the sound only when I play out loud but there isn't anything wrong with the speakers?!?!?!?!?
Posted Fri 09 Jan 09 @ 12:05 pm
what are you hooking it up to..did this just start,,check your cables to make sure its not the cable sending the feed.
Posted Fri 09 Jan 09 @ 1:33 pm
IM HOOKING IT UP PERFECTLY I THINK THERE MAY BE SOMETHING WRONG WITH THE BOX OR SOFTWARE
Posted Fri 09 Jan 09 @ 2:07 pm
