Hey! I just got Pro and downloaded the mapping and all that! But, i have some problems!
My first problem is that the "up" browser button goes down, when i configer it to the "Browser_updown" in the rmx mapper! The "down" button goes down, but still have the problem with the "up" button!
Also, I seemed to have "lost" the Effect button 1 & 2 ability, the ones where u hold down (this is the standard that comes with VDCE) the "flanger" button and then can use the "jog wheels" to adjust the effect buttons! How can i map that back, and can i map it on every effect! Would be nice to have that ability on for example "cut", "Phase Shifter", "Beatbox" and soo on! Actually every effect! Can this be done and how?
If anyone can help me, i would appreciate it A LOT!
Thank you for your help!
DJ Odin!
(For dere fra Skandinavia, gjerne svar på norsk, dansk eller svensk;)
DJ Odin!
Posted Mon 05 Jan 09 @ 2:13 pm
Why dont you use the native built in mapper in Virtual DJ?
you dont need to download a mapper... just activate it in Virtual DJ (remove your mapper first)..
My guess is that the mapper you have downloaded is made to change the way the default mapper works, by for example swapping keys (that you didnt want)
Try the default mapper and see if its more to your likings ;)
Posted Mon 05 Jan 09 @ 4:09 pm
You've got to bare in mind aswell that the mapper ( Moramax's RMX mapper, I hope we are talking about) is at the moment still in it's early Beta stages, and it may still need some work to it to get it perfect (I'm happy with it so far)
So untill then, why don't you do as Rune says and acitivate and use the default setting for the RMX in the remote control tab. And come back to it, when a new version is released.
Posted Mon 05 Jan 09 @ 4:31 pm
Okey, thanks! Because, the reason i downloaded the mapper, was because I wanted to use downloaded effects on the 6 buttons, which I could not do with the default mapper! But guess ill just have to wait!
Thanks a lot! :)
Thanks a lot! :)
Posted Tue 06 Jan 09 @ 1:11 am
if you're using the RMX mapper,i suggest t read very well the pdf manual. It's explained how it work.
Posted Thu 08 Jan 09 @ 2:31 am
