Can this tool work for Mac?
Posted Tue 06 Jan 09 @ 10:50 pm
Andrew87 wrote :
Hehe thanks. I'll add the ability to browse for the tracklisting file in the next version, I left it out for now because I'm not sure the My Documents folder is accessible by other users. The thing I would like to refine most is the html layout, e.g. option to output as a table and a better layout.
I don't believe security is an issue for most people.
I reckon most people who do not have a dedicated DJ PC will simply have a different windows profile for use when jocking, and a different one for everything else! Both profile will be administrators so will be able to see each other's my documents folder!
For me I only use my DJPC for just that, DJing. I do not even have a keyboard plugged in (I use the virtual keyboard)! I use another computer to sync my music and remotely manage the machine, so it would be great to have an 'open database' option where I can simple network browse to the history file!
This feature would allow me to generate my playlists after a mix without the need to actually be on the computer!
Hope this makes sense and thank you once again for this priceless tool =Þ
Posted Wed 07 Jan 09 @ 1:48 am
when i try to install this i get the message "virtualdj has encountered a porblem and needs to close" any ideas?
Posted Wed 07 Jan 09 @ 6:49 am
Sorry for a little go out of thread, but is this also possible for vdj playlists or can be create?
Thx's
Haui
Thx's
Haui
Posted Wed 07 Jan 09 @ 7:30 am
No as it is .exe not dmg for the application part.
However it should work in bootcamp.
Posted Wed 07 Jan 09 @ 12:11 pm
djsynystr if you're running Windows XP you need the .NET Framework 2, but there's still some bugs I need to sort out before I'd recommend doing so.
djsynystr the program should run on a MAC if you use Mono but I don't know what the filepaths are on a Mac to automatically load up data and it may be buggy.
DJAuz that seems like a good idea, do you use external harddrives on that machine? I'd have to add the ability to manually load each database in the event of a network share as I don't think it's possible to do it automatically as the drive paths would be unknown.
Haui70 I could add a feature to print out playlists as well as history, maybe soon.
Posted Wed 07 Jan 09 @ 9:59 pm
@ Andrew87, will be great.
Don't hurry and a great Job!:-)
THX
Haui
THX
Haui
Posted Thu 08 Jan 09 @ 3:07 am
This has been needed for a LONG time, good job mate ;o)
Posted Thu 08 Jan 09 @ 3:36 am
