Forum: VirtualDJ Skins
Topic: Denon DN-S1200 Skin! - Page: 2
DJ mix mac wrote :
Don't you know how to copy-paste with Paint? ;)
unfortunately, I don' t know how to. I spent almost 4 hours Sunday with paint in PC and Gimp for Mac trying to do just that.
Explain me how to or please do it for me.
I can make one for you.
I have a friend of mine that have those players.
I will let you know next month when is done.
By the way i just realize i have two users name. can some body delete the no license one . please
Thanks
DJCHOPIN, thank you In advance. I will be waiting for that skin!
wonderfull skyn
dj rhum in mix wrote :
wonderfull skyn
Has the skin been finished and published where Is the skin. It has been two weeks guys!
he asked you to wait until febuary
OK the skin is finished. but have one problem.
Since i don't have the DNS1200 i need some body to PM or post here a complete list of what each bottom do in VDJ, with full description please so the skin can be adapted to the default Virtual DJ support.
Since i don\'t have the DNS1200 i need some body to PM or post here a complete list of what each bottom do in VDJ, with full description please so the skin can be adapted to the default Virtual DJ support.
Thanks man.
gonna have it done next weekend.
DJChopin, here Is the rest of the modifications made to the mapper of the Denon DN-S1200:
Description:
Description:
Changes In Mapper:
Minor bug.Pitch Slider Button Is corrected
New functions:
A/B Trim Button----Switches between Active and Cue deck
Quick Jump/Fast Search Button Left and Right---Move into the song foward and backward with minimal audible sound
Interruptions
Disc Eject Button------Clone what is playing on the Active deck to the default deck.
-Cue Butoon deck 1 & deck 2--------Play_Stutter back to the cue point
-Play/Pause button deck 1 & deck 2 --------same
-Echo/oop Button deck 1 & 2---------synch
-Flanger Button deck 1 & 2-------Pitch reset with reset checked---meaning once pressed back to o% Pitch
-Filter Button deck 1 & 2----Synch_nocbg
-A1 button-Play Stutter Auto deck 1 & 2-----Play & synch song from the other deck for mixes
-Next Track Button 1 & 2-----select O Active deck---select Active deck and Cueing deck
-Tap Button 1 & 2-----Manually fix the BPM by tapping the beat.
If "Smart BeatTap" is activated, the grid tapped will automatically be snapped to the nearest likely grid.
Title/ID3-UTIL.-----Video_Open- Activate Video open and close video screen
-Flip Button deck 1 & 2----Go_to cue point
-A2 Button deck 1 & 2----Loop In Auto--hit to mark starting point of the loop
-B Button 1 & 2----Loop out-hit to activate that loop point marked and the end of the loop
-Exit/Reloop Button---Loop_Exit
-Time/Cont/single Button deck 1 & 2---Set_Cue point
Everything else are the same like the old mapper
Denon DN-S1200 midi mapper
Author: RonnieB
Hey DJCHOPIN, Is that DN-S1200 skin done yet?
posted for ggalvan...
d(^;^)b When can we have it?
hermoso , beatiful , i cant wait for the denon skin , thanks ....
GGALVAN, what happen? are you done with the DN-S1200 skin? If you are done with the skin; did you submitted yet?
skin looks really nice so far, cant wait 2 try ... :-)
63%
