On the recommendations of a few posts here I purchased Audio 8 DJ Soundcard. Output is really good but the timecode signal is so poor it's unusable in a timecoding mode. I'm using the VDJ TCCD's and haven't had a problem with it in the Hercules Contollers; do I need to use different TCCD's for this soundcard?
Posted Sun 28 Dec 08 @ 5:18 pm
I have audio8 and it works perfect with vdj with the same timecode cds.
Maybe something is wrong with your configuration.
Have you done auto config to get 100% quality?
Posted Sun 28 Dec 08 @ 8:01 pm
Yes I have and it remains at 0%.
Here are some specs for you:
HP Pavilion dv9220us,
Windows Vista 32bit,
Intel Centrino Duo 1.6 GHz, 2GB RAM,
Western Digital External HD 300GB,
2 Pioneer CDJ 1000's,
Pioneer DJM 3000 mixer,
Virtual DJ 5.2.1 Pro,
VDJ TCCD's Professional Grade
Audio 8 DJ with Driver Version 2.0.5.001
Audio 8 DJ Settings
Input Timecode CD/Line
Standard Latency (for now)
Audio 8 DJ Settings
Posted Mon 29 Dec 08 @ 1:19 am
Sonath are you using conventional RCA's to connect your CD Players to your Audio 8 DJ or are using the multicore cables?
Posted Mon 29 Dec 08 @ 10:14 am
I use conventional RCA's, I use numark cue (it's the same wiith vdj) and I don't have any problem.
I don't know why you don't get 100% quality.
Try to move the gain sliders to timecode config.
Posted Mon 29 Dec 08 @ 4:44 pm
Screenshot your settings, that might help us alot :)
Posted Mon 29 Dec 08 @ 5:11 pm
Took a minute but I figured it out.
In the Time Coded Vinyl configuration I had to check the invert stereo box and that seemed to do the trick.
Posted Mon 29 Dec 08 @ 7:00 pm
