Looking for help connecting Torque Conectiv to Virtual DJ with 2 Denon decks.
Posted Sun 28 Dec 08 @ 2:24 pm
CD or Vinyl?
You would connect to the unit exactly the same way as torq.
Then choose on sound options:
Inputs : DUAL TIMECODE
OUTPUTS : External mixer
Souncard : ASIO
ASIO DRIVER : MAUDIO CONECTIV
If you where using Torq Vinyl you would go to time code options and choose noise map as the engine.
If you are using CD it would be advisable to download the Virtual DJ CD signal.
https://virtualdj.com/products/timecode/cd.html
Souncard : ASIO
Posted Wed 31 Dec 08 @ 7:26 am
