what mixer can l use with vdj pro so l can use a mic and headphones
Posted Thu 25 Dec 08 @ 11:12 pm
Any mixer with microphone and headphone connectors.
The important thing is that you really need a soundcard with two stereo outputs.
Posted Fri 26 Dec 08 @ 5:42 am
thanks sbdj my laptop has two stereo outputs so right now l'm using both one conect to amplfier with two speaker and the other connect to my stereo so l can use the speaker from my stereo ,mixin with the total control l tried to use the dijio sound card but l get better sound with my set up any mixer model brand please and you have better soun set up how? thanks
Posted Fri 26 Dec 08 @ 10:01 am
I've got no experience with the DJ I/O I'm afraid.
I use an Ecler Evo 5 - it's a 4 channel mixer with a mic channel and headphone support obviously. It has a built in firewire soundcard, so the audio is output straight to the mixer.
You can use any mixer - with a 4 channel soundcard set VDJ sound to external mixer and both channels will be output. You then use the mixers headphones and mic functionality to mix, and output from that to your amp :)
Posted Fri 26 Dec 08 @ 2:26 pm
