I would like to create a excel data base. how can i do that useing the XML for virtual dj
Posted Thu 25 Dec 08 @ 9:15 pm
not sure that is possible
what you could do is use Directory listerr to create a listing of all files in your music/vid folder
this will be be in the form of a txt file
how u get it into Excel is another thing
but a least you would have not have any additional coding if you opened your xml database file
Posted Fri 26 Dec 08 @ 10:35 am
