Hi Guys,
I'm new to all this so just bear with me,
On my headphone options for mix i can only get the master output.
Anybody got any ideas.
Thanks
Keith
Thanks
Keith
Posted Mon 22 Dec 08 @ 6:59 am
First of all, be sure to download the latest driver for your console ( from the Hercules support site) as well as the latest update for Virtual DJ , as many issues have been corrected since the version that came on the provided CD.
Next, let's start with the configuration of the MK2:
- In the MK2 control panel, leave the setting to WDM
- Connect your main speakers to output 1/2 at the back of the console, and your headphone to the appropriate output
Launch Virtual DJ, then go to the Sound Setup, and configure as follow:
- Input : None
- Output(s): Headphone
-Soundcard: DJ Console MK2
- Input : None
Posted Mon 22 Dec 08 @ 7:55 am
Cheers phatso,
Updated all software etc,
This is probably silly question but where is the sound setup located,
I checked in configuration and cant find it.
Thanks man
Thanks man
Posted Mon 22 Dec 08 @ 9:36 am
Hello topdog8,
In VirtualDJ DJC 3.4.1 (the version of VirtualDJ included with DJ Console Mk2), you have not the menu mentionned by Phatso, this menu is in VirtualDJ Pro.
With VirtualDJ DJC 3.4.1, once you have connected headphones on the front headphones output on the Mk2, you should have no issue to preview deck A or Deck B when you place the "Headphones Selection" switch on position Deck A or Deck B.
By default, whether you are in deck A or in deck B position, if you don't change the "Headphones Selection" switch position at the beginning of the mix, VirtualDJ DJC 3.4.1 will change automatically the preview source each time you load a new music track.
Posted Mon 22 Dec 08 @ 10:03 am
Hello topdog8,
Hey Dude, Thanks for the help.
I have no problem listening to either tune on deck A or Deck B when i switch from either. But if i want to preview my mix it wont allow me,
and virtual dj doesnt do this automatically when i load on a new tune.
Posted Mon 22 Dec 08 @ 10:23 am
Bump::::
Anyone else any ideas, need to try get it sorted as having a few paties over the xmass..
Thanks guys
Thanks guys
Posted Mon 22 Dec 08 @ 12:17 pm
ok,For some reason i cant even get on tha website to download the latest version of hercules dj.I bought this product and im ready to send it back.I cant even enjoy it.Please help.
Posted Fri 16 Oct 09 @ 6:50 pm
Hang tight Tony, some times web sites need to back up their info, so they become un-available. I would suggest waiting about an hour or so and trying again.
Posted Fri 16 Oct 09 @ 8:09 pm
Please I need help :
I have Virtual DJ 5.1 and just bought Hercules DJ Console mp3. In the Remote Control section of Virtual Dj 5.1 it says activate Hercules which I have done but I can't contol it with the hercules. What should I do ?
Thank you.
Thank you.
Posted Thu 06 May 10 @ 3:35 am
@ Urigol
Did you buy the Hercules DJ Control MP3 OR DJ Control MP3 e2?
The e2, which is more recent than the original MP3, is only natively supported from version 6.03 and upward.
Posted Thu 06 May 10 @ 6:28 am
It has to be the DEFAULT sound card and need to set it up for QUADRAPONIC or 5.1 surround sound speaker system. (Windows Control Panel SOUND SPEAKERS ADVANDED CONFIG)
Posted Thu 06 May 10 @ 2:16 pm
My problem: I cant hear Deck A or Deck B through the headphones. I can only hear the mix and split.
I have Virtual DJ vers 6.1 pro, Hercules DJ Console MK2 and my laptop runs Windows 7.
I have downloaded the lastest Hercules drivers I think it was called 2010 or 10.
Any advice?
Any advice?
Posted Fri 11 Jun 10 @ 2:56 pm
i need some help guys!!!
i've just update my older virtualdj, to virtualdj7 pro.
i am using hercules mk2..with older version, it worked perfect. with vdj7 pro, i have a big problem..i cannot hear anything from the headphones until i pump up the volume(but then sound goes to the speakers too).
i downloaded and install the latest drivers of mk2, but the problem still exists...
my situation is desktop pc-mk2-mixer-amplifier-speakers
is there anyone to tell me what i have to do with the sound setup to fix this problem?
thank you
thank you
Posted Tue 24 Jan 12 @ 2:35 am
@ Gruppo 7
It is sometimes better to start a new topic then to revive one from 2 years ago...
That being said, what audio configuration are you using in VDJ ?
Posted Tue 24 Jan 12 @ 6:40 am
ok if you have the original disk load it... there is a driver in it that fixs this issue.. the same driver is not in the pro series as im using the same windows and had same issue... I posted step by step instructions... have a issue still I will send you a link.. also update the driver from herc web site..
Posted Thu 26 Jan 12 @ 5:00 pm
