Forum: VirtualDJ Skins
Topic: Vinyl Scratch v6.0 - Page: 5
its a nice skin !!
I'm with djlilfasay he gets a + 1 from me as well
& L2
only asking out of interest would it be possible to add all the options there to the top box using another button
1= default as it is 2= over laping waves 3= split waves
or to do it just by clicking the box area so it toggles threw them ? don't know weather that's even possible though lol !!
just a thought because i like all the options
also thanks to sslover for the v6 skin
I had a whole big reply with suggestions but i timed out so i am not retyping all that lol
Use the grid Luke!! feel the beat! If you guys would let go of the ryhthm waves and listen to the mix your learning to mix better ...Oh wait that is so 1990's lol
I will add the wave options SO you can choose how you like. I will have to test what delivers the best view since all the options will have to fit within the same space given.
I'll upload the current fixed version then later when i have time i'll pannel up some waves.
the force in me is strong my friend (well ish) lol !!
that would be great and should keep everyone happy
whahahaha good one.
thanks man i hope to see it soon !!!!! no.1 skin on my list!!!!
ok i uploaded a new version, i was playing a bit more with waves fandos had done, but i expanded the area and make them a little taller, plus eliminated grids altogether. I suggest a zoom at about 19% or a little more but you can do what you like. let me know if it works better.
wow nice :-D thats great, is there a way to add a button like to switch from 2 waves above each other to the overlapping 2 waves?
excuse my english ^^
friend listen your skin even errors, behind the buttons there are waves......
sory for my English is very bad
ejemplo..................
also i noticed cue points arentshown in the waves and in the middle the white line to see when the beat actually is played is black !
That is what I told to listen2
the line in the middle was the way fandos had made it i just used the same image. I didnt want a big line in the middle, so i kept it the way it was.
Is that button bug still in the latest version? I cant make it appear for my life... maybe i upload the wrong version. I'll have to check
edit: your image is from the older version because i took out the dB from the gain. try redownloading
cue points were never added.
you beat me to it !!
i was just trying the skin and your update is fine
Ive been clicking all over the skin to try and recreate that bug but couldn't thought i was going mad lol !!
thanks L2
what have you planned to update ?:-)
What do i plan to update more? Probably not too much, maybe some tweaks. I think I really want to move on to more original skins. I think things are pretty good in this skin.
Vinyl Scratch Vert Waves|Cues|Grid
A varation of the Vinyl Scratch Vert with Grid,Cues and Waves shown
Im working on a variation with overlapping waves also.
Edit by Cioce
External skin link removed, your skin will be approved maybe tomorrow
djlilfasay
sounds interesting will keep my eyes open for that one
thanks for takeing it that one step further its all way over my head lol !!
my vercion:
Hey Fandos you beat me to it!
I had a older version when i made this skin for version 4 with video and i was going to add it again... i guess i wont, good job!
EDIT:
- Overlapping Waves
- Cue|Grid Shown
EDIT:
- Bigger Waves
- Editied Skin
- Cue|Grid Shown
Both soon online
Listen2, you have big problem in your skin:
The vertical scratch waves dont match the sound actually.
I can scratch, before im actually visually at the beat.
I´ve fixed this in my version. take a look. set a cue point at a kick or snare with a diffrent skin switch over to yours and scratch youll notice that the visual scratch wave doesnt match.
You just need to change the height to fix it!
please dont put your skin creations on filefactory, or any similar file sharing websites.
please post em up in the skins section.
thankyou for reading.
thankyou Cioce for moderating.
70%
