sischo wrote :
You already can:
right-click on the BPM field; the left-click allows to you to use the TAP option.
Is this something programed into your new skin, or it that built into VDJ??
Posted Thu 05 Mar 09 @ 7:57 pm
sischo wrote :
You already can:
i mean with out doing all that just a copy grid button
Posted Fri 06 Mar 09 @ 1:08 am
What do you mean?
That is possible just creating an appropriate .xml file
Copy grid button??
I am sorry, I don't understand.
Posted Fri 06 Mar 09 @ 6:57 am
sorry..
i'll explain a bit more..
i understood the above about the BPM 'the other way round'
i thought there was a funtion where you could 'left click' the bpm to adjust, and right click to bring the bpm window to make adjustments.
Posted Fri 06 Mar 09 @ 11:49 am
sorry..
You can do that in the browser.
Posted Sat 07 Mar 09 @ 9:06 pm
If you do right-click on the mouse positioning the pointer of the mouse on BPM field, you get straight the BPM window section:
Posted Sun 08 Mar 09 @ 8:02 am
OK, i follow the right click to get the BPM window to adjust all the parameters, but could we program a left click on the bpm number to 'beat tap' direct on the skin??
maybe its not possible?
Posted Sun 08 Mar 09 @ 8:13 pm
Yes, that works yet!!!
Try to left-click on the BPM field going to the tempo and it will set right the BPM number.
Posted Sun 08 Mar 09 @ 8:31 pm
Great :) i'll try it with this skin. should have thought of that before, sorry.
Posted Sun 08 Mar 09 @ 9:24 pm
hey whats up,
this is a question for the ssllover creator of the vinyl scratch skin,
what are the readings right about the tcv signal strength indicator in the middle , it says 05A or 08A and if u click on them it says Cm# or DM#,
what do they mean,
i just started using tcvs and this skin is perfect since i use the rmx for the soundcard,
great job!
what do they mean,
great job!
Posted Sun 29 Mar 09 @ 2:40 pm
Cm# or DM#, is the songs key and 05A or 08A is the camalot number used for harmonic mixing have a search in the forum plenty of info about it
have a read of this thread
https://virtualdj.com/forums/102283/General_Discussion/HARMONIC_KEY_MIXING_-_SIMPLIFIED__with_Virtual_DJ_.html?search=camalot&page=1
aubs
aubs
Posted Sun 29 Mar 09 @ 2:53 pm
oh like Cm means a C minor and dm as in D minor?
Posted Sun 29 Mar 09 @ 2:56 pm
have added a link to my above post
Posted Sun 29 Mar 09 @ 2:58 pm
thanks man...
Posted Sun 29 Mar 09 @ 3:21 pm
Any possibility of adding a shift knob?
Thanks.
Thanks.
Posted Wed 08 Apr 09 @ 12:34 pm
that would be good actually.
Posted Wed 08 Apr 09 @ 12:51 pm
to move the loop?
Posted Fri 10 Apr 09 @ 5:57 pm
i think he meant to move the waveform, like the "pitch-bend" feature, yknow
Posted Fri 10 Apr 09 @ 7:00 pm
Thanks.
Thanks.
I think he meant a shift loop knob
slider chan="1" action="loop_move" relative="yes" orientation="round"
pos x="X" y="Y"/
size width="X" height="Y"
clipmask x="X" y="Y"
fader move="circ"/
slider
Posted Fri 10 Apr 09 @ 7:37 pm
I think you all got it. It's the shift knob on the default skin which you can adjust the position of the loop.
Posted Sat 11 Apr 09 @ 7:45 am
