Topic: Big Problem!
Help,
my vdj.exe is going bananas! I already have:
  • -tried all kinda combos on the settings
  • -reinstalled several times /w manually removing all vdj posts in the registry for a clean new setup
  • -change some hardware
But still I got this problem. At idle, my CPUs at 0%. And all other progs I run has normal behavior. It\'s not spy ware or anything like it, i\'ve checked all services running.
As you can see my virtual dj takes up 60-65% CPU AT IDLE!!! And of course if I\'ll analyze a song, it\'s up in 100%.
ANYONE GOT A SUGGESTION WHAT TO DO?! ALL HELP APPRECIATED!
Posted Sat 29 Nov 08 @ 3:35 am
Which one is your problem with virtualdj.exe?
The problem is that Virtual DJ is using allot of CPU when i start the program. When it should be 0%, it's 60%.
And I have no idea how to fix it. Or why it's like that.
Could it be because
-I've tried to hook up timecodes?
-I've tried to get the video recording to work?
-VDJ is searching for a module that I've deleted?
It's strange that VDJ uses a lot of CPU not doing anything.
I can suggest to "reset to factory settings" available by INFO pannel.
That would have been my advice too.
And what are you computer specs?
I see you use ATI video card, try reinstalling drivers and Control Center and disable video recording. It must be some setting you activated video>VDJ related.
Do you have Sonique activated??
Thank you for all replies!
I've allready tried to reset to factory standard and so on, so I don't think it's VDJ itself that has a problem. I have disabled the video in VDJ with no difference...
The specs is 1GB ram, 3GHz CPU, INTEL chipset, Radeon X1650 PRO, Audigy 2 soundcard.
The computer had no problem with VDJ before, so I think it might be something like the ATI card or something.
I decided last night after a gig, that I'm gonna format the computer now, so hopefully I will have no trouble with the fresh install.
