I RECENTLY UPDATED MY HARDDRIVE TO A LARGER HARDDRIVE
I COPIED ALL MY FILES EXACTLY FROM MY OLD HD TO THE NEW
I RENAMED THE PATHS THE SAME..ex..F:\laptop\MAIN\Dancehall WHEN I COPIED MY MUSIC TO NEW HARDRIVE
!!!!!!ALL MY MP3FILE INFOS ARE GONE..NO CUE POINTS, BPM ETC!!!!!!
I USED A BACKEDUP OLD DATABASE XML FILE AND REPLACED IT
WHY ISNTVDJ RECOGIZE THE SAME FILES? ONLY THE HD IS DIFFERENT?! MUSIC,VIDEO, CPU AND DATABASE ARE SAME!
HOW CAN I GET VDJ AND MY NEW HARDDRIVE TO REMEMBER MY OLD CUE POINTS, TIMES PLAYED, BPM AND ALL OTHER INFO THAT IS SUPPOSE TO BE SAVED IN THE DATABASE FILE
FILES HAVE BEEN COPIED EXACTLY
PLZ HELP IT TOOK YEARS TO COLLECT THE INFO.
Posted Fri 28 Nov 08 @ 5:05 pm
This might seem an obvious question but..did you reboot after pasting the XML data?
Posted Fri 28 Nov 08 @ 5:23 pm
thanks but rebooting didnt work
Posted Fri 28 Nov 08 @ 5:45 pm
Either the xml is not located at the root of the drive containing the music, or paths are not exactly the same.
Your new drive must have the same letter, if not, you could do a search/replace to correct the xml.
Posted Sat 29 Nov 08 @ 4:52 am
