I use VDJ with my laptop, dual core, vista dell 1530 2gig ram memory only 5months old....I was running slide show as a plugin with my mp3's ..."use this plug in with mp3's" in the video tab of config.... it worked fine for about an hour then I loaded the next mp3 but noticed only a quarter loaded up...it would load a karaoke song all the way but not mp3...any Idea???
THANKS
THANKS
Posted Wed 26 Nov 08 @ 1:52 am
go to config options maxload should be always try that .
Posted Thu 27 Nov 08 @ 1:33 pm
thats what to do go to config/options bottom right hand corner and change to max load.will defo work
Posted Thu 27 Nov 08 @ 1:35 pm
thanks guys...I did do that...that night. when the problem happened..will have to try at an upcomming gig.....
Posted Thu 27 Nov 08 @ 3:05 pm
Does it solved the issue? If not, you might have problem with ram memory.
Posted Thu 27 Nov 08 @ 3:36 pm
I have the same problem with music, not videos. After a while, you go to load a song and it stops like he said above and then loads slowly just ahead of where it's playing. Then you load a video, and it works. The CPU usage is 0 while this happens too. Seems related to using sonique or any other thing like the slide show. Then it's like that till you reboot the program. It appears that it runs out of ram. Mine has 3 gigs of ram but Virtual will never use more than 1 gig? Oh well, maybe more people will post the loading problems on songs and someone will figure it out.
Posted Thu 27 Nov 08 @ 4:05 pm
last post is correct...I wanted to use slide show as a plugin with mp3's 2.5 hours later is where i had the problem, or like i did the night before with sonique...
again it's a new laptop DELL XPS 1530... with windows vista home pre.... 2gigs of memory 32 bit op sys intel (R) duocpu T5550 @ 1.83Hz with NVIDIA GeForce 8400M GS.....
thanks guys happy turkey
Posted Thu 27 Nov 08 @ 8:09 pm
changing that setting did not help me that night
Posted Thu 27 Nov 08 @ 8:11 pm
