WHY IS IT WHEN I TURN UP THE GAIN,EQ,EFFECT,OR THE CHANNEL FADER THERES LIKE A POPPING SOUND IN WHICH IT SOUNDS HORRIBLE,THE VERSION IS 5.2, IN WHICH I BOUGHT FROM MY FRIEND FOR $150.NUT THE PRIZE ISNT THE PROBLEM.CAN SOMEONE HELP,OR ELSE I RATHER GET "SERATO SCRATCH"OR "TRAKTOR SCRATCH PRO".
Posted Mon 24 Nov 08 @ 8:02 pm
I'm hoping your friend did not sell you a cracked version because re-selling VDJ is not allowed. Do you have the serial number? If so, please register the software.
We would need more info in order to assist you.
Are you using timecode?
Are you using a controller? If so, which one?
External Soundcard? If so, which one?
What are your CPU specifications? How fast? How much memory? Operating system?
Using a external mixer?
Please provide more info and also, please search the forum. There are threads on popping sounds, configuration, tweaks and fine tuning.
Try this,
https://virtualdj.com/forums/58149/General_Discussion/SELECTED_GUIDES__setup__performance__hardware___tips___tricks_.html
You may find an answer in that thread.
Try this,
Posted Mon 24 Nov 08 @ 8:19 pm
