Ok ive just bought my Big 500w dj speakers, the 1600w amp to go with it...
When i run my VDJ & Hercules RMX i basically have the USB from PC to Hercules, And then run the output to amp and the amp to speakers. This works absolutley fine and sounds PERFECT.
BUT!!!!!!!!!!
When i use mylaptop (which im gunna use for gigs) i do the same set up, use the USB lead, Output to amp from the RMX and for some reason it starts off fine playing the tunes, then after bout 10 seconds whenever you move a corss fader or a pitch adjuster it makes a STATIC NOISE. has anyone ever had this happen?
I've asked a few people and they fink it may be because it isnt earhted, but i earthed the mixer just now and it still does it, the only other thing i can fink of is that the USB ports are not as good on a laptop as they are on my PC?
ANy help greatly appreciated
BUT!!!!!!!!!!
Posted Mon 24 Nov 08 @ 3:49 pm
Untick Safe Mode, and Overclock. And adjust your latency settings.
Posted Mon 24 Nov 08 @ 3:59 pm
adjust latency settings to wot?
Posted Mon 24 Nov 08 @ 4:01 pm
have you the latest drivers installed from hercules and are you using vdj version 5.2.1 if not register the rmx with the serial code found on the back of the cd cover in "modify my profile" and pick up version 5.2.1
Posted Mon 24 Nov 08 @ 5:44 pm
Set Preset slider to the left (fastest)
Latency set to Auto (from drop down)
Posted Tue 25 Nov 08 @ 12:25 am
Hammer,
Try unplugging your laptop from the mains.
I had this very same issue and found it to be white noise from the power brick of the laptop. I tried plugging the laptop in to its own extension block and even running a seperate extension cable from a different wall socket but that failed - and anyway its not always possible to do this...
When I unplugged my laptop from the mains the static/white noice disappeared completely - I noticed this when at one gig the noise was so bad I tried to resolve the issue while playing. This is when I noticed the noise going when I unplugged the laptop from the mains.
Eventually I experimented with a 3rd party generic power supply made by myonis (www.myonis.com) and now I get no noise whatsoever and my laptop charged correctly.
I got me new power supply from www.laptopshop.co.uk and it cost me £25!
They even have a tool to match the correct supply with your laptop http://www.laptopshop.co.uk/laptop-ac-adapter,ac11.htm
Cheers,
Roy
Cheers,
Roy
Posted Wed 26 Nov 08 @ 11:05 am
Hammer,
Or you could try one of these mate, and only a tenner :)
Posted Wed 26 Nov 08 @ 12:19 pm
Jimmy,
I tried a ground loop isolator and it had no affect - well for me anyway...
Hammer,
If you can borrow a GLI that would be a good start as you can see whether that solves the problem. If not then you may need an alternative power supply.
The first thing we need to check and clear though is that when you unplug your laptop the white noise goes away.
If its any help, my laptop is a Gateway dual core.
Cheers,
Roy
Hammer,
Cheers,
Roy
Posted Fri 28 Nov 08 @ 4:47 am
i had the same problem with my laptop.what i ve done is i put a bit of paper between the plug and the plug socket so i actually isolated the ground from the plug.the noise is gone and im doing it anywhere i go to be safe.
Posted Fri 28 Nov 08 @ 5:36 am
"Untick Safe Mode, and Overclock. And adjust your latency settings."
How do you do this? I'm having static problems also, but don't see how to "adjust latency settings."
Posted Tue 02 Dec 08 @ 2:02 am
In VDJ go to Config>Performance and untick safe mode, and there is slider, put it on fastest (most to the left).
If you set "auto" that slider has no effect ;)
Posted Tue 02 Dec 08 @ 3:53 am
How do you go to config???
Posted Tue 02 Dec 08 @ 7:58 pm
Nevermind, figured it out...had to get the temporary upgrade.
Posted Tue 02 Dec 08 @ 8:55 pm
haha are you all talking about that stupid crackly noise which is caused by over lock and safe mode, just untik them mate, they are gay
Posted Wed 03 Dec 08 @ 8:34 am
