Hello! I am a newbie to the site. I have the Stanton C.314 CDJs and VDJ. I'm using Vista.
When I use my CDJs to try and config the timecode it will not work. There is always a 0% timecode quality.
Posted Sun 23 Nov 08 @ 9:14 pm
I'm sorry I'm using Virtual Vinyl.
Posted Mon 24 Nov 08 @ 1:42 pm
you may need to download the Proffesional timecode and burn it to cd (in the downlads section above), this is because the output may be too hot for the virtual vynil box input to handle. in the advanced view do you have any sort of waveform at all (also dont forget to switch the input on your box to line mode)
Hope this helps
Pattie
Hope this helps
Pattie
Posted Sat 29 Nov 08 @ 11:09 am
