I have searched around the forums for answers but with no success.
I just bought VDJ pro and noticed the karaoke manager plugin doesn't work. When selected, there are no settings or activation button on the right side window. I have tried reloading directx 9c and the VDJ pro program. Didn't help.
THe Sonique plugin won't acitvate either.
On the slideshow feature, pictures of different ratios will strech to fit the screen, distorting the image. I know people have been having this problem but couldn't find a thread where the problem was fixed. Is this still a hopeless issue?
Thanks for reading this and looking forward to some input!
Posted Mon 15 Sep 08 @ 6:49 pm
For the karaoke manager and sonique plugin issues try this thread:
http://www.virtualdj.com/forums/95136/VirtualDJ_Plugins/Plugin_not_working__Controls_not_showing_______Read_this_before_posting_____.html
For the slideshow problem, you need to register your copy of VDJ pro, and then you will be able to download my slideshow plugin which will correctly cope with the image dimensions.
Regards,
Scott
Regards,
Scott
Posted Mon 15 Sep 08 @ 9:26 pm
