A common cause of ASIO error is a drivers installation internal procedure.
Some WDM/ASIO cards installation drivers files automatically sets the soundcard as windows playback default device, when installing.
Once windows needs WDM to work, the OS sets the card to WDM on start-up.
So, when we try to start VDJ, the soft cant set the card to ASIO once the device is in use by Windows.
Then, the error...
Maybe an Hercules owner should know what I am talking about.
So, check your windows playback device before anything, and if your ASIO/WDM card is the set as default, change it.
Then, the error...
Posted Wed 09 Nov 11 @ 8:54 pm
My Virtualdj sound is not working good and i need asio sound card driver to make it work.
Thank's.
Thank's.
Posted Tue 15 Nov 11 @ 11:02 am
Virtual DJ/Atomix (this forum) does not supply ASIO drivers for every sound card on the market.
You need to install the drivers which came supplied with your ASIO card.
If for some reason you don't have the drivers, you need to go to the support or download area of the
card manufacturers web site and get the drivers from there.
Posted Tue 15 Nov 11 @ 12:38 pm
Hi guys,
I have experienced the same problem and I fix it by updating the soundmax driver under sound, video and game controllers in the device manager. BTW, i am using windows 7 professional with dj console RMX. Hope this help.
Posted Sun 20 Nov 11 @ 12:02 pm
Equipment: Numark Mixdeck Express, Hercules MK2 controller.
Softwate: Virtual DJ Pro 7.
Problems: Error in the asio sound drivers.
Error Message Mixdeck: Not enough channels, your soundcard is not connected.
I have been using a Hercules MK 2 controller for about 2 years now which worked fine inspite of an error message sometimes with the ASIO driver. However now that I bought the Mixdeck Im having problems. I works but i cannot get the fader on the mixdeck to corrolate with the on screen fader in virtual DJ. Also the ASIO settings in the config menu do not respond at all, when i open Virtual with the mixdeck connected the error message pops up immediately..... Can anyone help me fix this.....
Posted Sun 04 Mar 12 @ 6:12 pm
Oh by the way, my system runs Windows 7, 32 bit......
Posted Sun 04 Mar 12 @ 6:15 pm
Please register your Pro serial number on the page http://www.virtualdj.com/users/edit.html and download the latest version from the Download Center: http://www.virtualdj.com/download/updates.html
If you haven't purchased VirtualDJ Pro, please support the software and its future development by purchasing it: http://www.virtualdj.com/buy/index.html
Re-install the ASIO drivers for the unit if it has them. If not, then you should configure it for WDM audio, which should be configured as follows:
Inputs: None
Outputs: External Mixer
Sound card: Choose the MixDeck Express sound card in the drop-down list.
Like the MixDeck, the MixDeck Express has a real hardware mixer and does not send MIDI for the mixer section, so you will not see these controls moving in VirtualDJ. If you need to know where a slider or knob is, simply look at it on the real hardware mixer of the controller.
NOTE: If you are using ASIO4ALL, then this may also be the cause of your problems. This is an ASIO emulator and will not provide true low latency sound as a real native ASIO driver would. Please see: http://www.virtualdj.com/wiki/ASIO4ALL.html
Inputs: None
Posted Mon 05 Mar 12 @ 5:10 am
boa tarde!!! reformatei meu pc e tentei instalar novamente o Hercules DJ Console Mk4, sendo que está dando falha em um dos software, de nome Hercules DJ Console Mk4 Bulk. Como eu poderia corrigir e fazer voltar a funcionar normalmente???
Posted Thu 06 Dec 12 @ 9:23 am
Sorry, this forum is for English language messages only.
Please either post your message again in English or use the appropriate language forum at the bottom of http://www.virtualdj.com/forums to post in your own language.
Posted Thu 06 Dec 12 @ 9:57 am
HELP ME PLEASE! I have downloaded the virtual dj I have the Pioneer ddj-ergo for Christmas I have hooked it up to my pc and.
1) cant mix with my headphones (everything I hear is playing on the speakers and also on the headphones it doesn't enable me to mix.
2) error in the asio sound driver: Not enough channels. I have no Idea what that means.
3)if I shut off my computer sometimes my virtual dj is not insync with my pioneer ddj-ergo.
If anyone can help me I would really appreciate it.
Posted Sat 27 Dec 14 @ 12:03 pm
