HI,
i am using VDJ 5.1 on Windows Vista service pack 1 ( 2gb of ram and a Turbo cache of 1gb ). I was mixing live with this laptop for 6 months without any problems. I was previously using Numark ICDX to control Version 5.07 and it was VERY easy and fun.
With the new CDJ-400,it is now not fun. I am using the CDJ-400 as soundcards since i've upgraded my firmware. BUt in Virtual DJ, i have now hiccup in playback so it is now impossible to mix to songs together because sometimes it's deck one that will hiccup when number play perfectly..Sometimes it's the problem goes to deck 2..Weird and unusable.
Who can help?
Best regards
Eric
Posted Fri 20 Jun 08 @ 9:48 am
Check your USB bandwidth
Posted Sat 21 Jun 08 @ 12:40 am
How do you do that? (checking USB Bandwidth) and what do you need to see?
Posted Sun 07 Sep 08 @ 9:35 am
Try to download latest 5.2.1 http://www.virtualdj.com/download/updates.html
Posted Sun 07 Sep 08 @ 9:57 am
In Windows, go to your hardware management. Then open the USB section. Right Click on a sub items and select properties. You will find data about power and bandwidth used.
Posted Sun 07 Sep 08 @ 11:44 am
