Do you guys have any problems with VDJ renaming Jay-Z tracks and other tracks that have a dash in the name as:
(file name): Jay-Z - Encore
(renamed by VDJ as): Jay - Z Encore
Very weird. Has anyone else seen this? I just noticed this. Looks like VDJ is having a problem with the dash in the name. Is there a way to correct the way VDJ sees the track/artist info? Thanks.
Killabee44
Killabee44
Posted Wed 17 Nov 04 @ 2:04 am
Rob,
Adding the dash will do it every time.
I spell it Jay Z - title.mp3
We can thank freedb for that I guess, just a no no when creating tags.
(-) is a known seperator and shouldn't be used for anything else.
Posted Wed 17 Nov 04 @ 2:31 am
Hmmm.. Ok. I guess I have to rename them. Shouldn't be that many... I will have to do a search and see..
Thanks.
Killabee44
Thanks.
Killabee44
Posted Wed 17 Nov 04 @ 4:21 am
Jay-Z kills me too. I renamed to Jay Z.
Posted Wed 17 Nov 04 @ 4:46 am
You dont have to rename them....
Download the parser.dll from here:
http://www.virtualdj.com/addons/download.html?addon_id=448">new parser
Unzip the parser.zip and put the parser.dll in the Virtual DJ root directory
This will fix the way songs are added to database.
Jay-Z - 99 problems.mp will be Jay-Z in artist, and 99 problems in title.
And O-Zone etc will work the same way.
With this new parser, artist and title are sepearted by [space]-[space]
In other words, "JAY-Z" will be together in artist column, and "99 problems" will be in artist, if the name of the file is:
Jay-Z - 99 problems.mp3
hope that helps ;)
hope that helps ;)
Posted Wed 17 Nov 04 @ 2:19 pm
The parser did not help mine. DOn't know why? I've had it loaded. Jay-Z still read Z Jay
Posted Wed 17 Nov 04 @ 2:22 pm
Simply remove the extra Hyphen ( - )
Everything to the left of the first hyphen will appear in the artist collumn. Everything after the first hyphen will appear in the title collumn.
Posted Wed 17 Nov 04 @ 9:10 pm
dj-in-norway,
Thanks for the info. I will try this and post back.
Killabee44
Killabee44
Posted Thu 18 Nov 04 @ 4:19 am
cannot find file after i rename then can any one help me lost a few song renaming them any suggestions
Posted Fri 19 Nov 04 @ 10:04 pm
If yoy renaming a song in VDJ and not in your folder (where are your mp3s is) then
DO NOT FORGET after the artist and track name to set also .mp3
so it goes like this: madonna-music.mp3(or wav or anything else your track is)
Posted Fri 19 Nov 04 @ 11:14 pm
Thanks a lot. It worked perfectly. Just drop the file in the VDJ root folder like dj-in-Norway suggested and re-scan the hard drive.
Killabee44
Killabee44
Posted Sun 21 Nov 04 @ 6:28 pm
Windows media player and OTS Juke DJ displays artist and song with all mp3 files. I have 3000, tracks of music that VirtualDJ does not recognise that way, how can I fix this problem without having to rename all tracks mike
Posted Fri 13 May 05 @ 9:36 am
Use the option READ IDTAG in version 2.1
Posted Fri 13 May 05 @ 12:19 pm
